Brake Light Problem
Old Oct 10, 2004 | 02:23 AM
PandaXpress's Avatar
Default Brake Light Problem
When I'm just driving sometimes my brake light (BRAKE) comes on for no reason at all, it beaps for like a few seconds then just goes away, it freaked me out so i check the manual but it was no help, i dont leave the hand brake up at all, so can some on tell me whats wrong with my baby
Old Oct 10, 2004 | 02:26 AM
David_K's Avatar
Default RE: Brake Light Problem
maybe a short circuit?
Old Oct 10, 2004 | 04:30 AM
SlimChriz's Avatar
did you check your fluid to see if its low?
Old Oct 10, 2004 | 04:58 PM
Jestnomen's Avatar
6th Gear
That light only comes on when a bulb is burned out right? Remove the access cover from your taillights and pull the bulbs out, to see if they weren't seated proberly.
Old Oct 11, 2004 | 01:05 AM
SlimChriz's Avatar
nah that light will come on if the fluid is low or the brake pedal reaches the floor
Old Oct 11, 2004 | 07:56 AM
marty's Avatar
I have a similar problem. Is it the same light you are talking about? Essentially the light on the dash that looks like a bulb with a cross through it intermittently comes on. A gentle wack on the rear left break light makes the bulb come back on and then the dash warning lights goes out after a while. I assume there is a loose connection or something? Any ideas anyone? I have a A4 TDi 130 Sport, havent had it for long, can anyone let me know where the access to the rear bulbs is please?
Marty
Old Oct 11, 2004 | 09:48 AM
Jestnomen's Avatar
6th Gear
A bulb with a cross through it is a burnt out headlight.
Old Oct 11, 2004 | 11:29 AM
marty's Avatar
In my specific case, the Driver Info system tells me its the Rear Left Brake Light, anyone know how to access it??
Marty
Old Oct 11, 2004 | 03:38 PM
Jestnomen's Avatar
6th Gear
Yeah, open your trunk. Remove the black access panel covering the light. It's easy, it will all make sense when you try to do it.
Old Oct 13, 2004 | 03:33 AM
My Brake pads where low and i got them replaced and the light has come on yet
Tripin
Apr 12, 2013 10:15 PM
luciddream42186
Jan 25, 2012 08:13 PM
ziggy64
Mar 10, 2011 09:13 AM
peterbr1717
Aug 13, 2010 03:28 PM
smoovmusicdj
Aug 22, 2007 10:27 AM
