brake pad change
Old Jun 5, 2007 | 05:56 PM
mcmani7's Avatar
Default brake pad change
i have an 03 A4 and im trying to change the brake pads but i cant figure out how to get the piston to go back in to put the new pads in
Old Jun 5, 2007 | 06:03 PM
TDRILL's Avatar
Default RE: brake pad change
Fronts, you can use any type of clamp. I used to use a big C clamp to push it back in.
On the rears, you need to turn the piston as you push in. They have a tool at Autozone or Advanced Autothat you can rent (like $50 but you get it all back when you return it). Just ask for the brake caliper tool. I ended up buying a new tool set since I won't be paying someone to do my brakes anytime soon. Works well for the fronts too (better than a C clamp). Get a ride and go get one before it gets too dark.
The reason you need to twist the rears is because of the parking brake setup on rear disk brakes, btw.
Also, make sure your brake fluid reservior is open (but doesn't spill out) and really you should open up the bleeder valve on the caliper so you don't push fluid back through the system (can mess with ABS).
Have fun.
jaymac
Feb 1, 2010 06:24 PM
airmancjh
B7 Models
Oct 5, 2009 11:44 PM
a4tink
Aug 25, 2008 10:52 AM
upgraders
Feb 4, 2007 11:02 PM
joeytattoo
Sep 4, 2004 06:13 AM
