brake problem
Old Jun 14, 2006 | 02:14 AM
crez's Avatar
Default brake problem
ive had my 2000 1.8t quatto for about a month and just recently ive got an intermittent abs light and also noticed a noise coming from the passenger side front wheel. its a swishing noise and almost sounds like my brake pad is constantly making contact with the rotor. also when i brake the car pulls to the right a bit. im thinking my caliper is shot. any other ideas?
Old Jun 14, 2006 | 01:00 PM
CRAZYHAWK's Avatar
Default RE: brake problem
Clean the wheel sensors. Make sure brake fluid is full.
Old Jun 14, 2006 | 01:14 PM
techbod's Avatar
service the caliper parts and check the break pads for excess ware as well as the above ^^
Old Jun 14, 2006 | 01:18 PM
onepoint8tee's Avatar
sounds like a seized/seizing caliper, or glazed rotors, which can be caused by a seized caliper which in the long run will warp your rotors and eventually cause your brake pedal to pulse when you brake. But if its pulling to one side, its probably time for a new/rebuilt caliper/rotors.
Old Jun 14, 2006 | 01:23 PM
techbod's Avatar
did you know the bolts holding the caliper on are actually pistons and have to work freely so the breaks release properly this is an area which is neglected when servicing breaks
Old Jun 14, 2006 | 01:27 PM
ORIGINAL: avant80@2.6
Good call... Gotta grease those mo fo's up every time you change pads. Ive neglected doing it before myself.
Old Jun 14, 2006 | 03:47 PM
crez's Avatar
thanks for the replys fellas, appreciate the help. yea im going to go ahead and order new front rotors and pads this weekend as the rotors are pretty worn. i saw some brembo cross drilled rotors on ebay for about $125 a pair for the fronts, sounds like a good deal....ive also been reading the tech articles on audizine or audiworld (i forget which) and they talk about cleaning and greasing up the bolts that hold the caliper on so im definetly going to try that before i replace the caliper.
Old Jun 14, 2006 | 03:54 PM
techbod's Avatar
all parts are serviceable, brembo drilled and crossed means less life on the pads but that's ok if you drive that way "definitely an improvement at a cost" but that's your choice
Old Jun 14, 2006 | 03:56 PM
techbod's Avatar
if you drive it hard the consider changing the break fluid to higher spec to prevent break fade
boosted517
Oct 13, 2020 11:30 AM
mpdc_1
Dec 28, 2007 01:05 PM
DavidElvin
Apr 18, 2007 02:52 PM
Dudek12
Dec 18, 2005 11:48 PM
west2005
Nov 7, 2005 07:36 PM
