Brakes!
Old Apr 7, 2007 | 01:42 AM
kraylon's Avatar
Default RE: Brakes!
i have the ebc red stuff if my car was stock brakes are not something to skimp on for example mygirlfriend has a 2000 carmy 4 cylinder andi have installed hawk pads all way around with cross drilled rotors even thought it is a camry you never know when you need those brakes to stop you in a big hurry it is better to be spend a little more and get something that could save your life or your car
Old Apr 7, 2007 | 03:20 AM
acetrebo's Avatar
Default RE: Brakes!
I have mintex red, and drilled rotors, the combo is very good, lots of stopping power. Have not tried the greenstuff yet. The red box were about $45 for me, well worth it. They are a good agressive DD pad.
Old Apr 7, 2007 | 03:51 AM
Greg9's Avatar
Default RE: Brakes!
Powerslots rotors, Grandsports GS6 Carbon Ceramicpads,Goodridge G-stop brake lines. This set up has been put through many hard100 to 50 mph and never let me down. You can buy them right from tirerack too
Old Apr 7, 2007 | 04:01 AM
SAudi's Avatar
Default RE: Brakes!
just get rembo rotors for like 200 for all 4 and then get green stuff pads
Old Apr 10, 2007 | 09:21 PM
CumminsPilot's Avatar
Default RE: Brakes!
Ended up with Brembo rotors all around and Mintex Red Box all around. Should be here and installed later this week.
Old Apr 28, 2007 | 01:52 PM
wolfdog's Avatar
Default RE: Brakes!
so how you like them?
Old Apr 28, 2007 | 03:01 PM
Default RE: Brakes!
Well, I only did the fronts so far. The rears still had about 50% left, so I figured no reason to swap them just yet (and after changing the fronts, I got rid of the warped rotor, so I was less inclined to do the rears).
The fronts bite good. I bedded them as hard as I could and it seems to have worked. The one thing I've noticed is that they do make a bit of noise. Not a lot, just a light squeal when on them very lightly (coasting to a stoplight or something). There is zero noise if you're really standing on them. They feel almost exactly like the stock brakes, which is good. Not too touchy/grabby, but they don't fade much either.
Haven't checked for brake dust yet, and only have about 200 miles on them.
mharris23
Jun 19, 2009 08:59 AM
DomsA4
Apr 24, 2008 06:53 PM
milla290
Jul 19, 2007 01:31 AM
dtownhotcorner
Sep 22, 2006 11:49 PM
dscott
Jul 4, 2006 06:14 AM
