brakes and fluid lights on instrument panel
Old Mar 1, 2006 | 04:22 PM
oda33398audi's Avatar
Default brakes and fluid lights on instrument panel
As Rod Sterling said; "Submitted for your consideration." I have the two trouble lights, brakes and brake fluid, which show up on the dashboard, that are now constantly on, plus on start up I get the beeping that there is a problem. Problem is, there is no problem with either system. I go to the dealer and they can't figure out how to tell the computer "no problem, turn off the warning lights and sounds". They suggest replacing the abs module (computer/valves, etc)box drivers side front in the engine compartment. As you might expect, the bill for that is not small, so I am wondering "HOW THE H--- DO I FIX IT???" Thanks for all responses...jvb
Old Mar 1, 2006 | 05:41 PM
avanttripleloop's Avatar
Default RE: brakes and fluid lights on instrument panel
rod serling.i dont have my car here right now but it should have a float level indicator on the cap or in the reservoir that may be stuck or faulty.i've never really checked mine but i know my v.w. has one on a rod under the cap.
Old Mar 1, 2006 | 05:45 PM
techbod's Avatar
float level sticking as the man says
stowaway322
Aug 26, 2013 05:31 PM
mawgui
Sep 16, 2012 08:18 AM
agmb
Aug 24, 2012 08:25 PM
alberta-s4
Nov 7, 2010 06:06 PM
descarl
Feb 10, 2007 10:51 AM
