Breather Hose
Old Jan 26, 2008 | 07:09 PM
AudimaniaA4's Avatar
Default Breather Hose
There is some knid of white/brown gunk with some water in my breather hose. Any idea's where that's from? Is that normal?
Old Jan 26, 2008 | 09:17 PM
dankhound's Avatar
Default RE: Breather Hose
Its from water in the crankcase. You may have a pcv valve problem or you may just take to many short trips. If you dont get the engine up to operating temp for longer periods of time water can accumulate in the crankcase and cause that milky buildup. Slight amounts of that buildup is normal, especialy in areas that generally have a higher humidity. If the whole pipe is pluged with it you have a problem.
SSEI173
May 25, 2014 04:31 PM
bmob222
Aug 30, 2013 03:05 AM
divil
Oct 11, 2009 07:10 PM
bontyal
Feb 23, 2006 04:03 PM
