broken glovebox
Old Dec 31, 2006 | 07:14 PM
IDTrav's Avatar
Default broken glovebox
Hey Guys,
Last night something was jammed in my glovebox so when I opened it the little plastic cylinder piece that makes it go down nice & smooth popped out of place. It doesn't look broken and through my searches hadn't found anyone else with this problem...how does this little mechanism work, can i fix it myself or am i gonna ahve to buy a new assembly?
thanks,
-Trav.
Old Dec 31, 2006 | 07:34 PM
BadLuckAudi's Avatar
Default RE: broken glovebox
probably gunna have to get the little part from the dealer
Old Dec 31, 2006 | 07:51 PM
SurferForever's Avatar
is it in 2 pieces or 1? If it just split just stick the one piece back into the other and it will work
Old Dec 31, 2006 | 09:30 PM
Zrowcool's Avatar
yeah theresthe cylinder thing and then a plunger which s on the glovebox. cylibder goes on the inside left and the plunger goes in it. pics would help a bit
Old Jan 1, 2007 | 01:19 PM
dankhound's Avatar
Depends which side popped out. On one side there is a little plastic pin holding the glovebox brake to the glovebox door hinge. The other side just fits in a slot in the side of the glovebox. You turn it 90 degrees and it cant come out. Are you sure the brake isnt locked up and the glovebox door hinge isnt busted.
Your friendly neighborhood chemist
Apr 6, 2014 09:30 PM
derZeck
Feb 22, 2012 02:53 PM
paintballcs
Dec 23, 2009 08:26 AM
rradovitch
Sep 11, 2009 12:21 PM
