Broken Thermostat
Old Sep 9, 2007 | 02:12 PM
SHARKBITEATTACK's Avatar
Default Broken Thermostat
My car doesn't heat up anymore and I think it's because my Thermostat is stuck open. Anyone know how to go about fixing this? 01 B5 1.8
Old Sep 9, 2007 | 02:34 PM
jrock's Avatar
Default RE: Broken Thermostat
Just replace it. They are cheap.
Old Sep 9, 2007 | 03:46 PM
wood_e's Avatar
Could be your temp sensor too. Those are equally cheap - about $15
Old Sep 9, 2007 | 05:00 PM
hiwords's Avatar
b4 u go spend money on anything, do some tests. have ur engine cold and then start it, put a thermometer in the reservoir and see wut temp u get when the coolant starts to flow. u don't need to do this if the coolant starts to flow as soon as u start the engine. not sure wut temp the 1.8 runs as but it should be around 170 i think. like wood_e said it could be ur temp sensor. and it's only $7 at autozone. and the thing that sends is the temp sensor so im guessing that is probably ur #1 culprit unless u got a bad gauge or sm.
derZeck
Feb 22, 2012 02:53 PM
paintballcs
Dec 23, 2009 08:26 AM
djmm
Nov 17, 2008 12:00 AM
zero388
Jan 13, 2008 04:38 AM
