A/C TEMP WON'T CHANGE
Old Nov 20, 2006 | 12:50 AM
neilechols's Avatar
Default A/C TEMP WON'T CHANGE
I have a 96 A4 and the A/C temp won't change no matter what temp you have it set at. I have ran the trouble codes on the head unit of the A/C and it pulled a 8.5 trouble code which is "Temperature Regulator Flap, static block". Does anyone know what this might be and if so how to fix it? I am dreading going to the stealership on this one. I have had this problem before and when I tried to pull the code it must have reset something because it started working just fine. No such luck this time.
Thanks
Old Nov 20, 2006 | 09:00 AM
david9999's Avatar
Default RE: A/C TEMP WON'T CHANGE
what was the actual code number that you pulled?
The temperature regulator flap directs the air over the heater core or the AC core. Could be short circuit, dead motor, or mechanical blockage
Old Nov 21, 2006 | 12:57 AM
neilechols's Avatar
I got the code 8.5 when I push the recirculation button and the up arrow above the recirculation button. Then I refrenced it by using the write up on audiworlds site. It refrences Temperature regualtor flap static block. I also got a 1c code this morning when I tried it again. I guess that is just refrencing that there is a system malfunction. I have not tried to pull any codes using a code reader.
May be a stupid question but do you know where this flap or the heater core is located? This doesn't sound like a DIY.
I appreciate the help, thanks.
Old Nov 21, 2006 | 02:20 PM
Amze's Avatar
"1996" - Theres your problem.... Lucky the airs run good so long =\
Pbcrazy
Aug 12, 2012 06:13 PM
katiebear00
Feb 28, 2010 01:19 AM
Audi 90Sport Quattro
Apr 12, 2008 11:31 PM
pete47
Apr 13, 2007 05:50 PM
LabattZ
Jan 10, 2007 08:22 PM
