car shuts off
Old Jan 17, 2007 | 05:47 AM
draudi's Avatar
Default car shuts off
i have a quick question. i have a problem and i wanted to see if anyone has encountered this, just to get an idea of how screwed i am before i go to the audi dealer or how much i am going to have to spend. i have a 1997 a4 1.8T. the car starts up fine and idles but then as soon as i press the gas the car shuts off. any ideas or suggestions?
Old Jan 17, 2007 | 07:21 AM
CRAZYHAWK's Avatar
Default RE: car shuts off
Check for codes and post them here.
Old Jan 17, 2007 | 08:44 AM
dan's Avatar
dan
Any mod work done to the car? how many miles? Does it idle properly or roughly? Will it idle for a long period of time on it's own or does it die at idle after a while?
Check the codes for sure, I'm betting it's either Clogged/blocked cat or the Intercooler piping has popped off or some other hose on the charge system.
Old Jan 18, 2007 | 10:18 AM
david9999's Avatar
Could be anything. Pull the codes and post them here along with any mods you have done to the engine.
Old Jan 18, 2007 | 01:53 PM
nickellis14's Avatar
throttle position sensor??? maybe??? RANDOM guess.
Old Jan 18, 2007 | 02:33 PM
techbod's Avatar
check for splits in the rubber piping from the MAF to the throttle body also any other vacuum pipes and any loose clips on the pipes
Old Jan 18, 2007 | 04:01 PM
tractioncontrol's Avatar
^^ +1
BananaClip
Oct 5, 2010 03:36 PM
crispy
Aug 25, 2010 08:29 AM
DanaB6
Jun 2, 2010 03:48 AM
MaCkAcHeW
Nov 27, 2008 03:47 AM
saved4use
Mar 9, 2008 04:52 PM
