Car Stereo Install woes
Old Jun 3, 2006 | 01:28 PM
Milez's Avatar
Default Car Stereo Install woes
I just had a pretty frustrating experiance with a car stereo install in my newly purchased 2003 Audi A4.
First, let me say that I successfully installed Sirius and a new BOSE OEM headunit with sat support (Thanks TeddyB!!).
Then onto the amp/subwoofer install. I found a remote from the HU wiring harness, ran power through the ECU and onto the trunk, grounded the with a bolt underneath the rear seat, connected the subwoofer and went to steal the audio off of the rear factory subwoofer using a line output converter.
While searching for the factory sub wiring to tap into, i found a factory amp behind the carpeting on the right side of the trunk. For some reason i thought my speakers were all powered off of the headunit; all the posts i read said the amp would be visible without moving anything.
So, I tapped what i am pretty sure is the subs wiring from the amp into the converter - no sub action.
Then, I tapped a pair of line level inputs and ran them into the converter (I know, i could just tap in with some RCA's and go right to the amp, but i thought the converter would still provide a signal) - this time i got sound out of the sub, but it was very quiet.
I'm starting to think the wiring diagrams i'm seeing around the forums for the bose amp are different than my year, or i'm doing something horribly wrong.
Thanks all,
Aaron
Old Jun 3, 2006 | 01:42 PM
techbod's Avatar
Default RE: Car Stereo Install woes
not my area im only into fixing cars but could it be your asking too much power from a standard system to power your subs
Old Jun 3, 2006 | 03:34 PM
VitaminB6's Avatar
I assume you are installing an amp for your sub. Ditch the convertor and pick up a line level signal going into the stock rear amp.
Old Jun 3, 2006 | 06:05 PM
BadLuckAudi's Avatar
dont do any of that stupid ****, wire in a set or RCA's directly behind the head unit its the best way to go for anything even close to decent sounding, a linelevel converter is a big piece of **** and will never work properly.... as onepoint8tee if you dont believe me wiring in the RCA's is the best way to go man
Old Jun 3, 2006 | 07:24 PM
Milez's Avatar
Thanks for the help! I'm going to attempt the RCA splice at the headunit harness.
While searching around i found this article that show my amp exactly and how to get to it...
Wish me luck.
Old Jun 3, 2006 | 07:48 PM
good luck
Old Jun 3, 2006 | 11:12 PM
AteUrV8's Avatar
"wish me luck"
"good luck"
LOL, thats great
Old Jun 4, 2006 | 12:02 AM
lol well thats what he asked for lol
Old Jun 4, 2006 | 03:56 PM
VitaminB6's Avatar
Yeah, I hooked in behing the HU because I wanted to control the cable and how/where it was routed, but most people have tapped into the factory wiring in front of the rear amp with good results. I wouldn't do it myself, but it is a hell of alot less work.
toolagit2qwit
Apr 30, 2015 12:52 PM
01S4
Mar 22, 2011 06:38 PM
nhill2090
Jun 30, 2009 11:48 PM
Ken4784
Aug 21, 2007 04:31 PM
noslipn
Feb 12, 2007 06:35 PM
