car stumbles on every start up need help
Old May 11, 2007 | 11:40 AM
stangs5088's Avatar
Default car stumbles on every start up need help
have a 2000 a4 5 speed. Car stumbles on every start up. hot or cold. no CEL. I looked around for vac leaks.. no luck.. any sugguestions thanks
Old May 11, 2007 | 11:43 AM
auditech79's Avatar
Default RE: car stumbles on every start up need help
Throttle body alignment. I think you can leave the key on for 5 minutes or so then turn it off and start it again and it should have aligned itself. Im not sure of that though.
Old May 11, 2007 | 02:54 PM
ironman's Avatar
does the car fall over when it stumbles, to align the throttle body turn car to on position, press pedal to floor and listen for 2 minutes, then leave key in for 3 more minutes, unless you have a vagcom.
Old May 11, 2007 | 03:13 PM
techbod's Avatar
check the intake pipe from the airbox to the throttle body are the clips tight or any splits in the rubber
Old May 11, 2007 | 07:09 PM
david9999's Avatar
Check for codes.
When is the last time you changed the spark plugs?
When is the last time you used some injector cleaner (a good one like techron).
2DoubleOTDuce
Aug 3, 2010 04:01 AM
2DoubleOTDuce
Jun 19, 2010 08:01 PM
xcmarty
Jan 15, 2009 02:59 PM
AUAvant
Nov 29, 2008 05:50 AM
jarawho
May 22, 2005 07:49 PM
