Sponsored by:
Sponsored by:
Car won't crank, relay 214 buzzes
Old 02-26-2007, 03:00 AM
DMSAudiA4's Avatar
Default Car won't crank, relay 214 buzzes
The car: 1996 Audi A4, manual transmission 2.8 V6 Sohc.
Problem: Turn the key, buzzing noise no starter action, engine won't turn at all. Car can be pushed started.
Starter has been changed, no changed still won't crank. However their is a continuous buzzing sound coming from the relay marked 214 when key is turned in cranking position, brand new battery.
Please help!!!
Old 02-26-2007, 03:03 AM
Audi_Skydiver's Avatar
Default RE: Car won't crank, relay 214 buzzes
Look up what relay 214 does.
Josh
Old 02-26-2007, 04:28 AM
DMSAudiA4's Avatar
Seems to be related to the Lighting circuitory, why would it buzz though? Does anyone think it might be the ignition switch acting up? Before this happened the key was turned once , no crank, twice no crank only turned over on the third try. After this it just refused to start. This is such a headache especially having changed the starter.
Old 02-28-2007, 10:50 PM
DMSAudiA4's Avatar
Ok, that relay was replaced, starter replaced, car still no starter action, just clicking of relays, I need assistance
Old 02-28-2007, 11:08 PM
Go through and check to make sure all your grouding wires are attached securly. Other than that idk.
Josh
Old 02-28-2007, 11:09 PM
DMSAudiA4's Avatar
Thanks Josh.
Old 02-28-2007, 11:38 PM
wood_e's Avatar
can you bump start it?
Old 02-28-2007, 11:39 PM
DMSAudiA4's Avatar
Yeh it can be bumped started pretty easily, pushings the hard part
iastudilloi
09-27-2018 04:41 AM
Todd's A4
09-15-2010 08:22 AM
mckeenr
11-25-2009 11:16 PM
micko
07-27-2007 11:55 AM
fryguy
06-24-2007 11:54 PM
Quick Reply: Car won't crank, relay 214 buzzes
