CEL Codes - Please Help!
Alright...I've been throwing the following codes on and off for the past 2 weeks:
- 17884 - EVAP Emission Contr. LDP Circ Malfunction/Insufficient Vacuum
- 17536 - Long Term Fuel Trim mult., Bank 1 System Too Lean
I tried to troubleshoot the problem this weekend by replacing all of the vacuum lines (which were pretty worn) with silicone ones, because that was my first though on vacuum leak...and also replaced the Secondary Air Pump (Smog Pump) because i've heard that is often the cause of some lean condition problems. Finally I installed a Forge 007 Diverter valve...just because I had the SAPump out and it was easy access.
So, i'm still throwing the same CEL codes...any ideas what the cause of this might be...? Thanks.
[confused]
[confused]
