CEL Codes - Please Help!
Old Dec 28, 2006 | 09:54 PM
jrodpikap's Avatar
Default CEL Codes - Please Help!
Alright...I've been throwing the following codes on and off for the past 2 weeks:
- 17884 - EVAP Emission Contr. LDP Circ Malfunction/Insufficient Vacuum
- 17536 - Long Term Fuel Trim mult., Bank 1 System Too Lean
I tried to troubleshoot the problem this weekend by replacing all of the vacuum lines (which were pretty worn) with silicone ones, because that was my first though on vacuum leak...and also replaced the Secondary Air Pump (Smog Pump) because i've heard that is often the cause of some lean condition problems. Finally I installed a Forge 007 Diverter valve...just because I had the SAPump out and it was easy access.
So, i'm still throwing the same CEL codes...any ideas what the cause of this might be...? Thanks.
[confused]
Old Dec 29, 2006 | 12:08 AM
tractioncontrol's Avatar
Default RE: CEL Codes - Please Help!
The insufficient vacuum can be caused by bad vsv valves or bad evap canister pump on non intrusive evap systems. The lean condition could be caused by a dirty MAF or bad o2 sensor readings.
Old Dec 29, 2006 | 12:47 AM
dankhound's Avatar
Most likely you have a vacuum leak somewhere in the vacuum line that goes to the leak detection pump. That would cause both codes to show up at the same time.
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
Ruggedboy
Jul 20, 2007 11:30 PM
supercoupe91
Jul 13, 2007 06:20 PM
rafa_207
Jun 27, 2007 01:31 PM
