CEL question
Well it popped up probably about a week ago and after my visit to autozone, the code was p0171 (engine too lean)
now after a little research (gotta love the search
), i see the culprits would bea exhaust/intake leak, the air system, MAF, or o2 sensor.
now i also saw somebody mention something about using an oiled filter (such as the k&n i use)... Would that be having any effect on why im getting the problem?
i was going to change my MAF sensor but i dont want to jump the gun if it could be something related to my k&n/airbox mod.... thanks for the help.
), i see the culprits would bea exhaust/intake leak, the air system, MAF, or o2 sensor.now i also saw somebody mention something about using an oiled filter (such as the k&n i use)... Would that be having any effect on why im getting the problem?
ORIGINAL: Turbulence
[quote]ORIGINAL: T28_A4
so ima jus submerge the sensor in the alcohol? it wont affect anything electric in it?
soak in 99% isopropyl or use an electronics cleaner...
ok, i stopped by autozone and got electric cleaner
i just pulled the box apart and sprayed it jurked around for a few and re-installed it, should be enough dry time
shake out any excess
akitamike
Jun 9, 2008 11:05 AM
SouthernAudi
Oct 14, 2007 06:47 PM
