CEL question
Old Dec 22, 2006 | 04:19 AM
Turbulence's Avatar
Default CEL question
Well it popped up probably about a week ago and after my visit to autozone, the code was p0171 (engine too lean)
now after a little research (gotta love the search ), i see the culprits would bea exhaust/intake leak, the air system, MAF, or o2 sensor.
now i also saw somebody mention something about using an oiled filter (such as the k&n i use)... Would that be having any effect on why im getting the problem?
i was going to change my MAF sensor but i dont want to jump the gun if it could be something related to my k&n/airbox mod.... thanks for the help.
Old Dec 22, 2006 | 07:10 AM
T28_A4's Avatar
Default RE: CEL question
ORIGINAL: Turbulence
it could be because some of that oil can get to the sensor and throw off the readings...that would be my best guess since you just did the mod too...try cleaning it first before you buy a new one, soak in 99% isopropyl or use an electronics cleaner...
Old Dec 22, 2006 | 02:29 PM
Turbulence's Avatar
thanks for the help... i think im going to do that now....
now where exactly is it located if anybody would be willing to share?
Old Dec 22, 2006 | 02:34 PM
techbod's Avatar
top of the airbox
Old Dec 22, 2006 | 02:39 PM
techbod's Avatar
[IMG]local://upfiles/12092/E35485B63ECE4CAAB828BC461DDC6EA0.jpg[/IMG]
Old Dec 25, 2006 | 05:10 PM
Turbulence's Avatar
[quote]ORIGINAL: T28_A4
so ima jus submerge the sensor in the alcohol? it wont affect anything electric in it?
Old Dec 26, 2006 | 12:55 AM
turbo kraut's Avatar
Tech Guru
ok, i stopped by autozone and got electric cleaner
i just pulled the box apart and sprayed it jurked around for a few and re-installed it, should be enough dry time
shake out any excess
EvoTillIDie1
Mar 5, 2014 10:42 PM
manindra
Feb 10, 2009 05:59 PM
SouthernAudi
Oct 14, 2007 06:47 PM
viper771
Mar 7, 2006 05:52 AM
