changing DV need help.
Old May 25, 2007 | 02:56 AM
cstarky15's Avatar
Default changing DV need help.
alright i know what to do to replace it, i got a forge 007 DV and all i need to do is replace the hoses like it looks like with the OEM one. whats the easiest way to do it? 01 A4 1.8T. from the hood or from under the car?
Old May 25, 2007 | 06:44 AM
BaconBait's Avatar
Default RE: changing DV need help.
You only need to replace the hose clamps, not the actual hoses.
Easiest way is from below.
Old May 25, 2007 | 10:39 AM
turboAUDI77's Avatar
do it under the car while it is jacked up. all you have to do is remove the plastic cover in a couple screws. the DV is right in your face once the cover is off then its only about a ten minute install because you need to cut the hose clamp. I used a zip tie in place of the old hose clamp.
Old May 25, 2007 | 10:44 AM
new2me's Avatar
I went from under the car like explained above & used the screw type clamps that came with it. Since me vac line going to the dv was deterating i replaced it with some line i bought at the local parts store.
Old May 25, 2007 | 12:49 PM
Jeff's Avatar
Zombie Defense Force
go from under the car. have fun with the one time use clams from hell
Old May 26, 2007 | 02:27 AM
cstarky15's Avatar
ok thanks for the help ill let you guys know how it goes. oh and one more question, which color spring should i use and with any spacers?
madridlover
Jul 2, 2012 01:44 PM
raudi28
Aug 17, 2011 02:13 AM
Booney1.8
Feb 7, 2008 01:27 PM
JOnJOn
Feb 6, 2008 11:41 PM
ZedEx
Dec 21, 2005 03:39 AM
