Check engine light
Old May 5, 2007 | 03:11 PM
mikowen10's Avatar
Default Check engine light
I have a check engine light on and had it read. I got a code P0171 and says it's lean on bank 1...does anyone have any idea what this means ?
Old May 5, 2007 | 03:16 PM
acetrebo's Avatar
Default RE: Check engine light
Probably a vac leak.
https://www.audiforums.com/m_390216/tm.htm
There is a search box at the bottom of the main page.
Good luck.
akielb's Avatar
SEARCH
Old Jan 4, 2008 | 06:22 PM
rogerpjr's Avatar
I am in real trouble. My ecu in my 1997 A4 1.8t ( 5 spd manual ) is apparently faulty. Somewhat intermittant. My A4 will start on occasion but 9 times out often the engine will just turn over. Once started it will remain running. I am in need I am told of a replacement ecu. I am new in Europe so I don't know who has the most reliable parts and at what price. I can import from my home ( USA) but there has too be a better way. Any ideas???? The ecu and firing harness was put on a device to troubleshoot the circuit. Hence my response. Thanks for you responses
Old Jan 4, 2008 | 08:38 PM
CLX's Avatar
CLX
Zombie Defense Force
Sounds like you need to trade your car for a Fiat Panda. Good luck with that!
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
huyaroo
Sep 12, 2007 03:37 PM
blanthony
Mar 25, 2006 01:18 PM
