Climate control
Old Oct 6, 2005 | 11:56 AM
dudley doright's Avatar
Default Climate control
Does the Audi automatically turn on the heater or air conditioning based on the temperature outside? I turned on the heater/air conditioning to auto the other day and left the temperature to 21 degrees and I noticed that heat comes out of the vent. I checked the temperature outside and I noticed that it was a bit chilly at 5 degrees. Yesterday afternoon I turned the heater/air conditioning to auto and cool air came out, while I noticed that the temperature outside was 26 degrees.
Old Oct 6, 2005 | 06:53 PM
sdaudi's Avatar
Default RE: Climate control
once you put it on Auto, Audi will take care of it. it's got a temperature sensor for the inside of the car. it uses that to regulate the AC/heating.
Old Apr 3, 2006 | 03:49 PM
apercele79's Avatar
once the AUTO is pressed, is it set as default that the heat comes at full speed?
first time i pressed AUTO, the heat came blasting at maximum level that i shyt my pants
lol
Old Apr 4, 2006 | 12:49 AM
xx18quattroxx's Avatar
auto just gets the car to the temp you asked for, the reason it picks vents is because some are more effective than others at either heat or cool... and a/c and heat for the defrost.
AnthonySlaughter
Aug 3, 2014 07:27 PM
a8audiv8
Apr 13, 2007 05:33 PM
cian_ie
Jan 10, 2007 07:07 PM
02A4
Mar 27, 2005 10:42 AM
