clutch install
Old Dec 9, 2007 | 10:05 PM
Bogie's Avatar
Default RE: clutch install
Actually, it is easier to unbolt the lower rear control arm when taking out the axles, rather than the uppers. The pinch bolt up top is a PITA and is probably seized up anyway. My car needed a 14mm allen head (1/2" drive) to remove the axle. Then once the axle was out of the hub, I just drove that bolt all the way back in and itpopped the outer part of the CV joint off the axle. Remember to clean everythinggood.Take out the six ***** by tilting thecage up all around, then remove the cage and "star", then remove the "star" fromthe cage and clean em allup good with paper towels. Make sure the outer boot clamps fitfirst before it's late and the stores are closed. Myboot kitscame with oet 92 clamps, and Ineeded oet 95 clamps...I gotsomeCv boot clamps atNAPA that worked out instead.
PCBOI808@HOTMAIL.COM
Apr 1, 2009 10:04 AM
1.8TK3MP
Dec 17, 2007 09:54 PM
BzeA4
Jul 18, 2007 02:48 PM
khj677turbo
May 23, 2007 11:26 PM
Deb38
Oct 31, 2006 10:04 PM
