Clutch Job
Old Oct 5, 2005 | 01:24 AM
kingming's Avatar
Default Clutch Job
Ok so my clutch pedal is on the floor... I figured out the slave cylinder was the culprit. Being the exploratory person I am I decided that since I have 79k on the car Maybe I should change the clutch pressure place and t/o bearing while I am at it. Got all the parts from ECS, they really are great. Not that bad of a job took me all of about 8 hours with taking the tranny all the way out. If anyone needs any pointers I might be able to help, but it is pretty much a straight forward job. Now here is my question should I change the fluids in the trans and rear, if so what fluid does it take? Thanks for the help. Also one other thing since I did the job now i have a rotational noise coming from what sounds like the r/r wheel only when braking. Noise increases with speed. But I did not touch the rear of the car. I did let it sit for a few weeks before i got the parts and the time to do it any ideas?
Old Oct 5, 2005 | 06:23 AM
sandman's Avatar
Default RE: Clutch Job
good to hear this isnt too dificult. working on my gear box is the one thing im scared of.
Old Oct 5, 2005 | 06:26 AM
flyboy's Avatar
ORIGINAL: kingming
good to hear. as for the noise it may be a baring, they are pretty commen from what I've heard.
Old Oct 5, 2005 | 07:55 PM
duhvinci's Avatar
Good to hear it! I may take you up on the pointers kingming, planning on doing the clutch in the next month. Any "devil" bolts down under?
Old Oct 5, 2005 | 08:00 PM
Silver98A4's Avatar
damn did you jsut start ripping **** out or where did you figure out where to start for the clutch
Old Oct 5, 2005 | 11:15 PM
kingming's Avatar
Jest the exaust bolts i had to let soak for a while... and getting the axles out i had to but a new extension with the hex head but other than that not to bad.. time consuming.
Old Oct 5, 2005 | 11:18 PM
kingming's Avatar
I just started ripping it apart as I went. first i dropped the exaust and drive shaft, and just went from there... the hardest part was bleeding the slave when i put it together took forever to get the pedal to get pressure. I bleed it for an hour at least. But i did have a lift and and a trans jack, w/o it is crazy to do yourself
Matt_Iliketurbopull
May 1, 2007 05:28 PM
Matt_Iliketurbopull
Apr 28, 2007 03:06 PM
