Clutch problem
Old Jan 30, 2008 | 06:52 AM
ikkezelf's Avatar
Default Clutch problem
Hi there,
Please help me.
I have a audi a4 '00
I can't get the car into gear when running.
When I trun of the engine the clutch seems to works again and I can get the car into the wanted gear.
Only when the car is started (or being started) the clutch does not seem to do it's work.
I have looked arounf the internet but couldn't come up with anything except maybe the computer?
Thanks in advance for your reply.
Old Jan 30, 2008 | 10:55 AM
tdn's Avatar
tdn
Default RE: Clutch problem
sounds like a your pressure plate is gone. stock clutch? how many miles?
I had the same thing happen to me, $1000 later, new southbend clutch works great!
Old Jan 30, 2008 | 11:23 AM
04ultrasprt's Avatar
Member
same thing just happened to me, needed a new clutch and pressure plate. Good luck
Old Jan 30, 2008 | 01:11 PM
bob12312357's Avatar
How's ur slave,fluid level and when was the last time it was bled.
Old Jan 30, 2008 | 02:14 PM
ikkezelf's Avatar
Hi,
tnx for the fast replies.
I tried to start the car by putting it in 2nd gear and when i truned the key the car broke foward.
This for some reason made the clutch working again.
Maybe the plates where stuck? The clutch is oke (for now), but probably this will happen more often, any new toughts with this new information?
thanks again
Old Jan 30, 2008 | 02:18 PM
Are u able to drive and it'll go slack after a bit of not shifting,and the clutch will sink to floor,and with clutch fully depressed gears grind?
Old Jan 30, 2008 | 02:24 PM
ikkezelf's Avatar
Hi,
No it works as it should be at this moment. not going slack at all, If I didn't knew something was wrong you would not experience it right now.
It looks solved for the timebeing, but I can 't believe that.
with regards.
Old Jan 30, 2008 | 05:03 PM
hb972.8q's Avatar
your pressur plate i just had mine redone. i had a stage 2 spec and replaced it with the same.
you will need a new flywheel. it will have hot spots on it and they are not cheep...i had to get a used one....oem $800 race $600 junkyard $80
Old Jan 31, 2008 | 06:54 AM
ikkezelf's Avatar
Just brought the car to the shop.
Now wait until they call me with the explanation of the problem.
jdwallace1970
Aug 10, 2013 02:39 PM
beetee
Jun 1, 2007 06:18 AM
Matt_Iliketurbopull
May 1, 2007 05:28 PM
Matt_Iliketurbopull
Apr 28, 2007 03:06 PM
dane
Mar 3, 2005 07:25 PM
