clutch question
Old Feb 16, 2007 | 03:00 AM
fullthrottle69's Avatar
Default clutch question
how long will my stock clutch last. i have an 01 a4 2.8 with 86g's on it. or how long should they last
Old Feb 16, 2007 | 03:06 AM
onepoint8tee's Avatar
Default RE: clutch question
Some last 40k miles, some last 140k miles. Depends on the driver. They probably SHOULD last close to 100k miles. Obviously the more highway miles the longer it will last also.
Old Feb 16, 2007 | 06:28 PM
TDRILL's Avatar
Right, its all in the driver (and the previous drivers). If driven correctly and nicely, your clutch can last a long time, but beat it or slip it a lot, and it will go much sooner. If you think it is starting to go, you can do a little searching here about how to check. A common one is to get up to about 30mph, put it in 5th, and floor it. If the tach doesn't move, your good, but if the tach jumps up some even though you don't start moving much faster, then you clutch is on the way out. Start looking for your replacement and a good shop to put it in for you.
Old Feb 16, 2007 | 06:35 PM
techbod's Avatar
if the clutch is used properly it should out last the car and you,
how many ride the clutch at traffic lights/ quickly rip through the gears to beat some one??
we all did it so no liesbut if you did then the clutch will last one third of the time ( approx ) or less same as the timing belt so be warned
Old Feb 17, 2007 | 01:16 AM
tfische12's Avatar
I have heard that the more drivers the worse it is for the clutch. I bought my car with 55000 miles and the pedal was pretty far up. I have 130,000 now and the clutch is the same. Just dont burn it and it will last forever. I have never changed a clutch in any of my cars. JUST DONT BURN IT OR RIDE IT, and it should outlast theengine.
Old Feb 17, 2007 | 01:21 AM
not much fun to drive like a grandma for salvation of your clutch. I say live a little burn it up every now and then and whenthe time comes toreplace it, just think back on all the good fun you had destroying it. You only live once.
Old Feb 17, 2007 | 01:43 AM
wood_e's Avatar
102k on my stocker... only slips a bit in 3rd when cold. RTock solid once the cars warm.
Old Feb 17, 2007 | 01:44 AM
jonus079's Avatar
i relpaced my transmission at 129k and did the clutch while i had the transmission out. when i compared the clutch disc that had 129k and the new disc, the old one still looked to have alot of life left in it. i was thinking maybe it was replace before but i asked my friend who sold me the car and he said the guy who had it before him had it since new and said he never replaced the clutch.
xb6boix
Nov 9, 2012 02:39 PM
manufan
Sep 22, 2008 02:33 AM
jsgrabo
May 19, 2008 03:23 PM
erkmeoff22
Aug 20, 2007 08:15 PM
a4r6
Mar 27, 2007 10:27 PM
