CODE P0118 Coolent Temp Sensor Failure!
Ok so some of you might have seen my thread about the misfire. Well i went and had my codes scanned and it came up with code P0118 which is a coolent temp sensor failure. I did NOT get any misfire codes. Weird. Anyways would that sensor cause my car to not start easly when the engine is hot? If it has been running at temp and then I turn it off it is pretty hard to start sometimes. What are your thoughts on this? Car specs are in sig.
Josh
Josh
