Sponsored by:
Sponsored by:
CODE P0118 Coolent Temp Sensor Failure!
Old 04-28-2007, 09:12 PM
Audi_Skydiver's Avatar
Default CODE P0118 Coolent Temp Sensor Failure!
Ok so some of you might have seen my thread about the misfire. Well i went and had my codes scanned and it came up with code P0118 which is a coolent temp sensor failure. I did NOT get any misfire codes. Weird. Anyways would that sensor cause my car to not start easly when the engine is hot? If it has been running at temp and then I turn it off it is pretty hard to start sometimes. What are your thoughts on this? Car specs are in sig.
Josh
Old 04-28-2007, 09:14 PM
auditech79's Avatar
Default RE: CODE P0118 Coolent Temp Sensor Failure!
The coolant temp sensor can make it hard to start the car whether its hot or cold, replace it.
Old 04-28-2007, 09:17 PM
onepoint8tee's Avatar
ORIGINAL: auditech79
+1
Old 04-28-2007, 09:18 PM
Could that cause any type of misfire thing? I am 100% sure I had a misfire yesterday but it didn't show up when they scanned my car.
Josh
Old 04-28-2007, 09:26 PM
auditech79's Avatar
Yep, even more so if you have a black coolant temp sensor, if you get a new one they should give you a green one.
Bad ects can cause whack A/F ratios. Too rich and you will misfire. Too rich, or lean, makes for a hard startup.
Old 04-28-2007, 09:28 PM
Hmm... I think I will order one of those on Monday! So i want the green one?
Josh
Old 04-28-2007, 09:30 PM
Just get it from the dealer. Its one of the fewthings you wont find for much le$$ anywhere else.
Old 04-28-2007, 09:32 PM
auditech79's Avatar
Yeah they only used to be $4, but the company that manufactures the terds increased the price to around $40, thats not very nice of them if you ask me.
Old 12-31-2015, 09:13 PM
live,laugh,love's Avatar
Default similar problems
when the car is having hard start does the shifter keep flashing?
johnscot
10-21-2013 10:29 PM
mark071973
05-03-2013 01:23 PM
babern00
03-03-2011 07:39 PM
Mr. Phil
02-23-2010 01:17 AM
critical
02-01-2008 03:48 PM
Quick Reply: CODE P0118 Coolent Temp Sensor Failure!
