Code Problem Help! Help!
Old Mar 13, 2007 | 05:01 PM
Hove_06902's Avatar
Member
Default Code Problem Help! Help!
Hey,
2000A4 1.8T Quattro. I woke up this morning and start the car, theengine light was on. So I got itscan for the code & the code I got was (P1113). So can someone tell me what causing the problem for the engine light to come on. And also a few suggestions on how to fix the problems.
Thank You
Old Mar 13, 2007 | 05:18 PM
techbod's Avatar
Default RE: Code Problem Help! Help!
faulty O2 sensor by the sound of it or wiring short
[IMG]local://upfiles/12092/42680C401E9F4422A827450E2261F4EB.jpg[/IMG]
[IMG]local://upfiles/12092/37534B3DBF5141F28B05F71D758D484E.jpg[/IMG]
Old Mar 13, 2007 | 05:23 PM
SacTown_Vlad's Avatar
this my help too
http://www.engine-light-help.com/oxy...sor-codes.html
Old Mar 13, 2007 | 05:29 PM
techbod's Avatar
very correct and a good link
Old Mar 13, 2007 | 07:24 PM
CRAZYHAWK's Avatar
17521 P1113 Sensor 1 Internal resistance too High
Sounds like an open circuit. Check for loose and dirty connections
to O2 sensor.
Old Mar 13, 2007 | 07:45 PM
onepoint8tee's Avatar
ORIGINAL: SacTown_Vlad
this my help too
Nice link!
By the way, check for a vac leak. I got that same code when I had a vac leak on one of the check valves on the back/top of the engine that works with the 2ndary air pump. Engines that have a 2ndary air pump for emissions at startup are 99.5 or 2000+. I replaced the cracked valve, cleared the code, and it has not come back so far. If you want to know which valve exactly check this out: There are lots spots in that general area that can spring a leak: https://www.audiforums.com/fb.asp?m=470168
Old Mar 14, 2007 | 01:31 PM
CRAZYHAWK's Avatar
P1113 O2 sensor heater resistance too high. look for aloose or dirty connection.
flipflop
Sep 23, 2009 10:00 PM
kiwi60
Jun 1, 2009 09:27 AM
osin34
Jan 17, 2009 01:08 PM
malubeast21
Oct 18, 2007 08:44 PM
mickyboy10001
Jul 6, 2007 04:43 PM
