Is this the correct way the DV should be installed?
Old Jan 23, 2007 | 05:27 PM
Philthykins's Avatar
Default RE: Is this the correct way the DV should be installed?
i had autozone scan the car and they found no codes. it peaks at 15psi holds at 13psi until 4500rpms then drops to 10psi and lower. Could my having the DV on backwards for a couple weeks killed my turbo?
Old Jan 23, 2007 | 05:41 PM
onepoint8tee's Avatar
no it wouldnt kill it. The dv will work the same either way its installed. Your boost #'s went up?I would replace the vac line (skinny one)that goes out the top of the dv accross the front of the engine and down under the intake manifold. If its leaking that will cause the dv to not hold boost well.
K1196A
Jan 7, 2009 11:02 PM
ChadS89
Jul 19, 2008 10:33 AM
kaptom540
Jan 24, 2008 08:53 PM
Philthykins
Mar 17, 2007 04:19 PM
cnelson81
Jan 27, 2006 07:16 PM
