Sponsored by:
Sponsored by:
crank breather hose
Old 09-30-2007, 02:29 PM
hiwords's Avatar
Default crank breather hose
i jsut noticed this on my car. is there supposed to be a joint piece like that on the crank breather hose? and there's some oil in it is this normal?
Old 09-30-2007, 02:52 PM
Default RE: crank breather hose
a little oil is normal and your second picture is correct
Old 09-30-2007, 04:07 PM
cincyTT's Avatar
I'm make believe
You might want to replace the hoses and clean out the hardlines. My brother has a '03 passat 1.8t and his hard pipes were clogged with oil sludge and we just replaced everything all the way to the intake with rubber hose and a catch can. The can filled up with fast with some nasty crap for about a month and ever since, his system has been running much better with just a small amount of oil in the can ever oil change.
Old 09-30-2007, 08:08 PM
hiwords's Avatar
im retarded and not sure what u mean cincytt. can u give me like a pic. im a stubbornly visual person
Old 10-01-2007, 01:02 PM
cincyTT's Avatar
I'm make believe
That hose leaves the valve cover and runs all the way to the intake. I would replace the hoseor clean them if they are clogged due to oil build up.
bmob222
08-30-2013 03:05 AM
grantwhite
02-05-2012 05:14 PM
vooo5269
09-19-2010 07:03 PM
SrK
09-08-2005 03:42 AM
Quick Reply: crank breather hose
