Custom intake with BOV....Idea for MAF
Old Jul 17, 2004 | 06:25 PM
bfiveafour's Avatar
Default Custom intake with BOV....Idea for MAF
I am about to make a custom intake with a cone filter. I know heat, heat, heat, but anyway I have a bigger heat shield and have duct cold air to the cone. My idea is that I want to install a BOV for the sound but also besides it making the car run rich I've heard it improves throttle response, etc... So here is the idea, if the car runs rich because the maf sensor is before the vented air then why not just move the MAF to the other side of the BOV like inbetween the intercooler and the intake mani. ??????? Would that not solve the running rich problem? I might just have to much time on my hands but what do you think
Old Jul 25, 2004 | 05:03 PM
David_K's Avatar
Default RE: Custom intake with BOV....Idea for MAF
get An apexi S-afcII it will trick the computer plus it looks cool and you can do a whole bunch of stuff with it. you can also use it to eliminate fuel cut if you decide to run more boost
Old Jul 25, 2004 | 05:05 PM
David_K's Avatar
HOw were you able to do that custum intake job b/c i need to do that
Old Jul 25, 2004 | 05:27 PM
ImolaS4's Avatar
ORIGINAL: bfiveafour
Sure... go ahead and try to move that massive MAF down the line. If you can do it with no other issues sneaking up on you, then you may have a great new mod. But, guess what? This question was addressed a couple of years ago. It wasn't practical nor effective due to the rest of the air:fuel ratio factors involved. If you put the MAF downline, as you suggest, then you have eliminated the new/fresh air intake values that are necessary for correct calculations.
BTW: Why do you think the BOV "...improves throttle response"??
Old Jul 25, 2004 | 05:31 PM
ImolaS4's Avatar
ORIGINAL: David_K
What are you talking about?
"....it will trick the computer plus it looks cool..."??
"....you can do a whole bunch of stuff with it."???
I don't want to "trick" my ecu.
There are a lot more functional items that can be installed into the engine that look cool.
Old Jul 25, 2004 | 05:34 PM
David_K's Avatar
sorry about that i sorta like to go the cheater route i understand that you value your cars also if you screw up with the AFC you cant destroy your engine once again sorry for that
Old Jul 25, 2004 | 05:35 PM
David_K's Avatar
oops correction you CAN DESTROY your engine that was a careless mistake by me
Old Jul 25, 2004 | 05:58 PM
ImolaS4's Avatar
Hehehe... no problem and no hard feelings bro.
410ThirtyValve
Jan 24, 2009 11:18 PM
TTMan
Aug 6, 2007 10:38 PM
Sp33d07
Sep 21, 2006 02:57 AM
quattrocket
Dec 31, 2005 07:17 AM
audihere
Apr 7, 2005 04:09 PM
