Cylinder 1 : oil on spark plug.. too much? pics..
Old Apr 25, 2006 | 07:54 PM
  #21
A4 the Quattro's Avatar
Default RE: Cylinder 1 : oil on spark plug.. too much? pics..
ya the car stuttered up top.. but smooth through the low range.. i cleaned the plug off and put it back in and so far everything has been running smooth.. i pray to god its not a headgasket.. i also just put my forge back in to see if that was indeed my problem and not the oil on the plug..
off to work..
Old Apr 25, 2006 | 08:14 PM
  #22
Beer Mod's Avatar
Head gasket is easier than you think trust me..........But I hope it's not for you to
Old Apr 26, 2006 | 11:44 PM
  #23
i did my compression check today
#1 perfect 200
#2 perfect 200
#3 perfect 200
#4 195
not bad..
anyway im still having bad problems with car stuttering under heavy acceleration.. it started doing it real bad again today.. and i have the 710N in.. so i ruled out the Forge as my problem..
today when i was checking my compression the plugs didnt look like they were at the end of their lifespan.. but ill try some new plugs and see if that helps my problem..
oh ya.. i just had a CEL come on as i was out driving around.. the car was sputtering under heavy boost.. and bam.. CEL .. [:@] ill take it tommorrw to the auto parts store and check my code
Old Apr 27, 2006 | 07:16 AM
  #24
techbod's Avatar
#1 perfect 200
#2 perfect 200
#3 perfect 200
#4 195
that's good readings so nothing wrong internal "look at the picture of the spark plug" you will notice there is no burning of oil on the tip so this tells you the oil was above the plug before it was removed indicating rocker cover gasket leak or over spill when topping up, when you say bucking "is that on hard acceleration" could be your pushing it too hard and hitting the rev limit, other problems here are mods like air-box drilling which effects the airflow and MAF sensor can give problems on readings
Old Apr 27, 2006 | 12:09 PM
  #25
TomRitt's Avatar
holy high compression! That awesome numbers, I think brand new they are around 180
Old Apr 27, 2006 | 04:35 PM
  #26
ORIGINAL: avant80@2.6
no its not me hitting the rev limiter.. and i have been having similar problems BEFORE i did the airbox mod [&:] .. i just started a new post about having a #1 cylinder misfire ... so im hoping maybe bad plugs or coilpack is causing my issue
sonsa4
Feb 13, 2012 12:09 PM
Pilipenko
Nov 28, 2011 10:06 AM
ee99ee
Oct 12, 2011 12:28 PM
Rowland2004
Mar 16, 2010 05:47 PM
auditurbo381
Mar 22, 2008 06:01 PM
