Damn CEL
Old Jan 9, 2005 | 09:39 PM
Jacek's Avatar
Default Damn CEL
Hey guys. I have a CEL code saying that I have a short or some happiness and something do do with the battery. I'm sorry by I don't exactly remember the correct name or code number. Has anyone ever had this type of code or does anyone know the exact problem and how to fix it? I tried to erase the code but it gets thrown again.
Thanks,
Jacek
Old Jan 9, 2005 | 10:01 PM
Transverse's Avatar
Default RE: Damn CEL
Next time it gets thrown, write that baby down and post it up! The more specific the better. Battery short throwing a CEL sounds interesting. What does your volt meter show?
-T
Old Jan 9, 2005 | 10:18 PM
Jacek's Avatar
When the car is on, the gauge shows just slightly under 14v
Old Jan 17, 2005 | 12:05 AM
Jacek's Avatar
Hello,
I found the exact code and it is (P1613) Open circuit/short with power.
What the hell is that?
Old Jan 17, 2005 | 12:23 AM
Doose's Avatar
Can you tie to anything? I mean, clear the code, start the car with everything off, then start turning things on until the code is thrown. Try that and let us know what happens. Sorry, don't mean to be vague, but this problem could be coming from a number of sources. At least this will start to narrow them down.
Old Jan 17, 2005 | 12:37 AM
Jestnomen's Avatar
6th Gear
You havn't switched ECU's lately or been chipped??
Old Jan 17, 2005 | 02:02 AM
Jacek's Avatar
My ecu was stolen and I had to get an ecu from a junkyard. It was from a 98 (same year as mine) VW 1.8t of the same vin section.
Old Jan 17, 2005 | 02:23 AM
Jestnomen's Avatar
6th Gear
This code can occur if the vehical you took the ECU from was a manual and you have a tip, or vise versa. The ECU may need recoded to your vehical.
Old Jan 17, 2005 | 02:26 AM
Jacek's Avatar
It would make sense. Where can I get my ecu recoded? Do I have to go to satan for this? Also, how much would it relatively cost?
Old Jan 17, 2005 | 02:34 AM
Jestnomen's Avatar
6th Gear
Well if you have a Vag-Com it would be free. The dealer may or may not do this for you. If they do, they will charge you about the same price as a Vag-Com. If you want to find someone in your area with one check this link out:
http://www.steve-hall.com/cgi-bin/VAG-Locator.pl
http://www.ross-tech.com/vag-com/cars/audiB5.html
coachvtt
Aug 9, 2010 08:55 AM
Palindari™
Jul 3, 2008 11:03 AM
CoBra03TerminAtoR
May 3, 2008 10:30 PM
mr.cAp
Feb 11, 2008 09:28 PM
bluovalguy
Jun 14, 2005 11:53 AM
