decisions, decisions.....APR or GIAC possible future K04
Old Aug 21, 2004 | 04:43 PM
David_K's Avatar
Default RE: decisions, decisions.....APR or GIAC possible future K04
to have it ported and polished and have the compressor wheel clipped it should run you around 350 at a decent machine shop. with the clipped compressor wheel it will spool much faster and since the turbine would be able to spin faster you could get 3-4 more psi out of it.
Old Aug 22, 2004 | 02:27 AM
trailboss's Avatar
That pretty much would be the same thing as a k04 but cheaper, the k04 is the same in size as the k03 just a bigger compressor wheel, am i right?
Old Aug 23, 2004 | 04:58 AM
audiboy1618's Avatar
David_k, Can you elaborte on the clipping of the compressor wheel, and being like the ko4?
Old Aug 23, 2004 | 09:42 PM
Doose's Avatar
Yes the K04 is the same as the K03 but the K04 has a 5mm larger compressor side. Exhaust side is the same.
Old Aug 24, 2004 | 08:16 PM
David_K's Avatar
"Clipping" is a process where material is removed from the exhaust turbine. This reduces the fin area exposed to the exhaust flow, so turbo lag will increase slightly. But at high rpms, a full turbine wheel will actually choke off exhaust flow, so clipping can dramatically improve high-rpm horsepower.
HeyCesar
Jul 31, 2013 01:13 PM
tommycin
Nov 24, 2008 07:33 PM
Sp33d07
Aug 15, 2007 06:35 PM
Trey25
May 23, 2006 03:57 AM
