destroyed AWD system
Old Jun 28, 2007 | 04:05 PM
khj677turbo's Avatar
Default RE: destroyed AWD system
On your evo?
Old Jun 28, 2007 | 06:59 PM
AudiOso's Avatar
What's the big difference between the B6 S4 6-Speed gearbox and the regular one?
Old Jun 28, 2007 | 08:16 PM
A4Rollin's Avatar
i can tell you this, i used to work at an audi dealer (how i got good deals) and when the b6 s4 came out SEVERAL of them were in the shop with trans problems. It was either it couldn't go into reverse or for some reason it always popped out of 2nd gear. Dont ask me why cause i have no F-ing idea but I can tell you I saw at least 10 b6 S4's come in the dealer because of this problem. And yah, the owners were pissed especially that the car was brand new at the time.
[/align]
Old Jun 28, 2007 | 08:19 PM
sean1.8t's Avatar
ORIGINAL: Lazer Viking
ORIGINAL: sean1.8t
if the A4 you are referring to is Mike Hoods, then i hope you know he recently broke his 2.8(suppossidly the strongest B5 transmission).. and many, many stage 3 B5 S4 owners(400-450Awhp) have destroyed transmission and many axles..
transmissions: $500-3000 + installation
axles: couple hundred and a pretty easy install
mike didnt break his 2.8 trans, he swapped the 1.8 back in for higher trap speeds
and as far as i've heard the only bullit proof trans is the b6 s4 6 speed..but there are only a few running it
no, he went for a 10sec run and broke his transmission. that is the original reason he swapped back in his 1.8 trans.. then he started to do research and found it would be better gearing for his motor
Old Jun 28, 2007 | 10:25 PM
Lazer Viking's Avatar
hm, i thought he was still doing shake down runs.. didnt hear about him breaking it
Old Jun 28, 2007 | 10:58 PM
pyropenguin's Avatar
Next run I tried to launch a little harder with a little more rpm but it seems the front diff had enough and let go. So I put the car back on the trailer and headed back to gregs house.
http://audizine.com/forum/showthread...41#post1675141
Hope that clears up some confusion.
emmpee
Oct 7, 2011 10:45 AM
feerocknok
Feb 12, 2008 10:29 PM
fobyulous
Feb 8, 2007 03:14 AM
