Disable the automatic window open/close feature?
Old Jul 9, 2006 | 11:12 AM
justinclarke's Avatar
Default Disable the automatic window open/close feature?
hi,
i have a Euro Audi A4 1998, and was wondering if you can disable the automatic window open/close feature when you hold the key in the lock for a few seconds ?
i have a vag-com and was wondering if i could use that to do it by recoding the central locking module?
if there isn't a way of doing it with a vag-com then....
i assume there are two wires connected to the central locking pump/motor that when the car is locked and still receiving a lock signal (i.e. someone is holding the key in the lock position) it passes the signal down through a 'window lock' wire which then triggers all the window motors from the drivers door. And the same for opening.
so if that is the case i can just cut the 'window open/close' wires at the central locking pump/motor ??
i don't know if this is correct, but it seems a logical to me.
basically i've got an aftermarket remote interface and the signal lasts too long on the open & close circuits, so therefore opens the windows a bit when i unlock the car, and then when i lock the car it closes them up a bit. so i'd prefer to just disable this feature.
does anyone have any ideas?
thanks.
Old Jul 9, 2006 | 11:17 AM
PJTocci's Avatar
Default RE: Disable the automatic window open/close feature?
On my old 3000GT, you could remove auto up/down (if you wanted to) by removing a diode on the window switch electrical panel.
To make it go up and down auto, you would place a diode where there should be one. For instance, it did not go up automattically, so that
would have been a fix for it.
Im not sure if that makes any sense, but I remember people on the forum doing this. There was also a plastic tab blocking the connections,
si that would be removed as well.
Hope that helps.
Old Jul 9, 2006 | 03:55 PM
cheers for that.
slightly confusing but gave me an idea.
basically the current that the unit is sending is too long, hence the windows rolling down a bit. so what i need to do is somehow stem / shorten the current that the unit is sending out.
i don't particularly know much about electonic but i'm sure there's gotta be a way of doing that, resistors spring to mind but i'm not entirely sure if they would help in this case.
any one know much about resistors and electronics ?
a6ontrack
Nov 3, 2013 04:04 PM
a6ontrack
Nov 3, 2013 03:56 PM
nottiaudi
Aug 4, 2011 06:36 PM
HoTiCE_
Nov 16, 2007 12:15 PM
