disconnecting abs
Old Sep 4, 2006 | 12:17 AM
sheek's Avatar
Default disconnecting abs
Any step by step instructions for disconnecting the abs system without setting off any faults. And can this be done without harming the module or other components which may still be working?
Old Sep 4, 2006 | 10:56 PM
sheek's Avatar
Default RE: disconnecting abs
bump. . .
Old Sep 4, 2006 | 11:00 PM
BaconBait's Avatar
What exactly are you trying to do?
Old Sep 5, 2006 | 12:01 AM
sheek's Avatar
My abs system kicks in just before I stop and it's annoying to drive around like that so I want to completely disable the abs system until I can get the problem fixed. I think it's a problem with the rear wheel speed sensors but now that school is starting I don't have the money or time to get those changed (assuming that'll even fix the problem, maybe it's the module). I just want it to stop engaging the abs everytime i brake before i make a full stop and I figure the best way to do this is to disable the ABS system completely. I'm not a car mechanic so I'm lookin for an easy way to do this, I've heard somethign about unplugging the module and also something about if one of the speed sensors is disconnected the whole system shuts off. I'm considering buying a car jack and taking a look around the wheels myself and cleaning out the sensors myself. If that doesn't work maybe just pulling one out and driving without abs?
Old Sep 5, 2006 | 12:08 AM
flyboy's Avatar
You can pull the fuse. you'll get the light but other than that.
Old Sep 5, 2006 | 12:13 AM
BaconBait's Avatar
Take your car to Autozone for a free scan. It should tell you exactly what the cause is.
t6dpilot
Jun 30, 2013 07:17 PM
cwedholm1
Mar 30, 2010 04:30 PM
millenia
Sep 25, 2008 09:22 AM
a4sport
May 17, 2006 03:10 AM
Alexa4
Mar 29, 2006 01:01 AM
