Engine vibration
Howdy fellas!
I did a trhottle body alignment on my b6 a4 yesterday and drove to work this morning with no problems. On my way home from work I find that under hard acceleration the engine starts to vibrate pretty badly and cel flashes, but at idle it seems fine, and under normal acceleration it seems fine, and after a few seconds the cel goes away. Haven't had a chance to hook up vag-tool yet, just putting out feelers. Any ideas? Help greatly appreciated.
What engine? Gotta have codes before attempting to help, but if the check engine light is flashing the engine is miss-firing, it may have nothing to do with the work you performed.
If you get the code and you have a specific miss-fire its probably the ignition coil but check your plugs first.
9 times out of 10 its the ignition coil on a 1.8T. When you remove the coil inspect it, sometimes they come apart in the center, most times the output stage in the coil is faulty, if the plug looks ok replace the ignition coil.
10kRedline
May 6, 2010 06:29 PM
