F*ck - central locks don't work - electrical issue
Old Aug 10, 2007 | 01:20 AM
auditech79's Avatar
Default RE: F*ck - central locks don't work - electrical issue
Bull Sh*t! You can access the central locking control module in any OBD 2 equipped audi, and you have to code it. Plug the old piece of crap in and see if it will comunicate with module 35.
Old Aug 10, 2007 | 09:02 AM
wood_e's Avatar
Alright - i'll do that after work... I'll try both modules too...
Old Aug 10, 2007 | 06:36 PM
wood_e's Avatar
Vagg'd it - ... controller not responding - tried that with both units... same result. The 5 amp fuse for the central locks and 15 amp fuse for the trunk lights/cent. locks are both good. I even swapped them with other fuses of the same type and nothing...
Any other suggestions?
Old Aug 10, 2007 | 06:48 PM
auditech79's Avatar
Both of those modules are garbage, instead of buying a new module pay the dealer an hour to diagnose it for you, that way when they say they know what it is and replace it and it doesn't fix it they own their mistake. Then they have to replace it. If the VAG COM says you cannot communicate with the central locking module you have a few things, the module is bad, the fuse is blown, or the wiring has a break in it somewhere. Chances are its the module.
Old Aug 13, 2007 | 09:04 PM
wood_e's Avatar
I would love to take it to the dealer except the nearest one is 45 miles away, and I haven't heard good things about them.
At this point... I think I should be looking at the fuses behind the knee panel under the steering wheel, and checking on the relays. I will also trace the wiring and check to see if any is melted or questionable.
Anyone know which relays control what on the A4?
shumi
Aug 31, 2012 06:48 PM
avantmanA6
May 21, 2011 06:00 PM
markymarc
Oct 7, 2010 05:56 PM
rally2
Aug 7, 2007 06:39 PM
InsaneHatter
Aug 11, 2006 09:41 PM
