Filling transmission oil
Old May 29, 2006 | 09:35 PM
bixing's Avatar
Default Filling transmission oil
Hey guys..
I opened up the transmission gear oil by mistake... a real silly thing to do.. but the good thing is i realised it before i drove off my car to wreck...
But although i did look at the link in audiworld to fill the oil but I cant find the opening... http://www.audiworld.com/tech/misc.html
If you could let me know....By some another pic..
Mine is A4-1996 FWD 1.8T
Thanx guys
Old May 29, 2006 | 10:58 PM
djlouieboom's Avatar
Default RE: Filling transmission oil
[:@] that sucks man ill see if i got a better pic in my bently manual
Old May 30, 2006 | 12:22 AM
bixing's Avatar
hey thanx man..
lemme knw asap.. coz my car is at rest till then
Old May 30, 2006 | 07:48 AM
well the pics in the manual look like the pics from the auid world tech article sorry i wasnt any help did u search this forum ?
Old May 30, 2006 | 02:27 PM
bixing's Avatar
I found a bigger nut which needs 17mm allen to open....(I used the 8mm allen to open a nut just few cm in front of the bigger one which drained the trans fluid) ..
So Is that 17mm the one from where I fill in the fluid,..In that case I ll probably have to pump it back in thru there!!
Also could you tell me which type of fluid I need., I did check other posts... and one said to use oil specific to car?? wat does it mean --So could I use the one that is GL-5 specific??
plz lemme knw asap...
thanx
My car is audi a41.8t fwd 1996 model.
Old May 30, 2006 | 07:43 PM
bixing's Avatar
Hey guys...
Please tell me wat type of tranny fluid to use for my automatic... the dealer's are the biggest stealers.. they dont knw wat type of fluid it is..but all they knw is that the label says ..audi atf......$£^*$%&(*)
Please let me knw asap... i got a pump to fill the fluid ....
THanx
Old May 30, 2006 | 09:14 PM
CRAZYHAWK's Avatar
VW automatic transmission fluid that meets ESSO EGL 71141
they carry pentosin
http://www.ecstuning.com/stage/edpd/...ro&engine=1.8T
Old May 31, 2006 | 12:05 AM
bixing's Avatar
Thanx hawk... man u r always helpin me out..thanx....
I ordered those.... But I actually was looking for something I cud get the same day.... my bad luck. no one keeps it at any local stores..
Old May 31, 2006 | 02:24 AM
david9999's Avatar
You could go to the VW parts dept and pick it up. It is about 15 dollars a liter and you will need at least 2.
filling the tranny is a PITA. the car has to be level fluid slightly warm (49 degrees C with a VAG temp reading, and you have to squirt it into the fill area until it just overflows.
However, you have now changed the fluid (at least what was in the pan) and you are good for another 30K miles or so.
Old May 31, 2006 | 07:56 PM
CRAZYHAWK's Avatar
The tramsmission should be around 105 degees F. I have 106K mi. on the origonal fluid.
redsoxsurfer
Feb 2, 2012 12:29 AM
virtualelvis
Aug 22, 2009 11:27 PM
bprzybyl
Jan 6, 2009 07:55 PM
tml
Apr 4, 2008 12:42 PM
Grossbauer
Jul 21, 2006 12:42 AM
