Finding 12V signals in a Canbus 04 A4
Old May 24, 2007 | 01:40 PM
KBIGGZ's Avatar
Default Finding 12V signals in a Canbus 04 A4
Hello-
I have installed an Avic-D3 in my 04A4 with "great success" (as Borat would say) minus a few things that appear to be canbus related.
+ I am going to extend the illumination wire from the H/U to a positive headlight lead in the engine compartment. Does anyone have advice on a relatively easy location to tap into this wire, and perhaps a picture of what said wire would look like? (no voltmeter). I need a 12v vs ground signal related to the lights.
+ My radio reception is junk. Is there an antenna booster post in the A4 or something to the same effect I can tap into?
Thanks for the help. I'm good with metal and wrenches but when I get into wires I'm lost....
KB
Old May 24, 2007 | 03:00 PM
KBIGGZ's Avatar
Default RE: Finding 12V signals in a Canbus 04 A4
OK -
I solved #1 with a little luck on the 1st try:
+ I found the harness that plugs into the driver's side headlight and unplugged it
+ I ran a wire from the illumination wire on my Avic-D3 to the harness, and tried different slots
+ The black and yellow stripe is the headlight wire (main driving light)
+ Tapped the wire, routed through the firewall and to deck
+ Voila
I'm still on the hunt for the antenna booster?
Old May 25, 2007 | 07:46 AM
KBIGGZ's Avatar
Will someone please confirm that this antenna adapter will solve my #2 problem? It appears it will supply power to the antenna booster when the radio is activated.....
This look like anything you've used?
Old May 25, 2007 | 08:20 AM
Aznpulse's Avatar
Member
that there my friend is an adapter to convert factory antenna to regular standard plug and yes I do believe it's powered. But there is a sepperate unit somewhere. I'm assuming your Canbus is Convertable? sorry never herd of that term.
yellow_submarine
Apr 22, 2015 09:56 AM
audimanthe
Jun 4, 2014 04:49 PM
audimanthe
B7 Models
Jun 4, 2014 12:15 PM
v8power
Oct 6, 2011 04:42 PM
Mevans607
Dec 28, 2007 01:29 PM
