first move
That a crock of BS man, i dont know who told you that but what they were probably saying was that It doesnt help as much as if it were with a k04, but it is by NO mean going to hurt anything at all.... I run one with my k03 and it pulls harder and longer, doesnt get heat soak at all and runs very well
ORIGINAL: xx18quattroxx
a fmic is not good for our cars with the stock k03... i dont know why but it screws things up... the side mount is actually very efficient
Im sure if you make a opening behind the IC in the wheel liner will raise effeciency tons. Granted you could get a s4 liner but Id rather do it for free and get more flow. A fmic on such a small inefficient turbo wont do good because the turbodoesnt flow enough cfms to make a fmic pressure drop worth it. Not only will you increase turbo lag incredibly but the pressure drop from the ic will kill your power.
I can testify that that is hardly true, the drop I saw was less than .5psi and it pulls so much harder it’s not even funny, yes in THEORY it will hurt but in actuality it does nothing but help
ORIGINAL: liquidxit2
ORIGINAL: BadLuckAudi
well my experience with ineffecient small turbos and fmic is limited. But all I have heard is that its onlt for the bling factor. I guess it depends on the core and end tanks you get that match the turbo.
Yea lots of people told me it was going to suffer performance wise but i had to replace mine anyway so i figured id upgrade so i had it for when i do go bt and like i said even with the apple sized k03 the gain is very noticable
ORIGINAL: illA41998
ah. one more thing too.
okay... somehwere along the line. my car started making this loud and obnoxious squeaking noise everytime i went over a bump or turned the wheel. i thought it was my suspension or some ****. but i took it to a shop. and they said they werent exactly sure. but they think i may have bent the control arm... and its rubbing against something. they did nothinga bout that. but they lubercated my bearings or some ****.. sound was a lot quieter. then it came back. and now.. i cant even stand it its so loud. i cant flex at all or it just sounds like ****. someone actually said they had a similar sound on their prelude. and they had to lubercate something dealin wiht the clutch. any ideas
I had the same problem on my 01 celica gt-s, I thought it was the control arm bushing as well. I took it to the dealership and they couldnt find out what was wrong with it. A couple of weeks later I got the car on a lift myself and had a closer look. It turns out i had 3 bolts on my motor mounts that had gotten loose and fallen out. With about $2.50 I got the replacement bolts and fixed it myself.
ORIGINAL: illA41998
