FPR change
ORIGINAL: chaos92287
until a can afford a full gt3071r .68 AR.
he spikes 22 and holds 20. and i beat him by 2-3 car lengths on average.
[/quote]
What the hell is a .68a/r? You mean a t25 .64 or a t3 .63? Both are still very differnt. Also stock evo's run 18psi.
ORIGINAL: daesharacor
Cincy - I've been trying to do some reading on mbc's, and after reading through the sticky and various searched posts, I'm still confused as to what the hell a proper one does. I've learned so far that you can either replace the n75, or run it in parallel, and it seems like people think you should run it in parallel because of smoother boost. That's fine with me.
In the diagrams on the sticky page, it shows a connection to the turbo housing. I don't have a connection to the turbo housing (k04), I don't think... If it's just boost pressure, is that the same as, say, the line coming off the intake manifold? or should i just figure out where the n75's getting the pressure reading from and tee it before and after, throw the mbc in, and leave it like that?
dammit, im getting more confused the more i write.... if it's in parallel, how does it help at all? I'd think that if it's completely closed off, the system is going to act just like it would without it, and if it's completely open, the system is going to act like there's nothing in (no n75).... dammit, why cant i know all the answers. /vent
honestly? wow. what else do you have done other than the k04 swap with normal file?
ORIGINAL: cincyTT
[/quote]
lol sry typo. meant to say .64 didn't even know they made a .63 tho. wuts the dif between the 2?
Josh
sollyd25
Jun 27, 2008 01:52 AM
