Freaking slow Tip..Arrgghh!!
Old Aug 5, 2006 | 07:13 PM
  #21
Somnio's Avatar
Default RE: Freaking slow Tip..Arrgghh!!
CVT in Tip mode seems to have better response than Auto Tip but then you miss out on Quattro
Old Aug 5, 2006 | 07:36 PM
  #22
socaljoe's Avatar
SoCal Crew Member
ORIGINAL: onepoint8tee
You can disable kickdown while in tip mode with vag com.. So if you are in tip mode in 2nd gear and you floor it you wont go into 1st and redline. I HAD to do it to mine it was getting so annoying.
I'll need to get the code for that, didn't know it can be disabled by VAG..thx for the tip onepoint8tee
ORIGINAL: Somnio
Yeah the long shift delay in tip mode is VERY annoying...can't wait for a company to come up with a chip for it
Old Aug 8, 2006 | 01:03 AM
  #23
shaggys40oz's Avatar
I think I must be new ... Uhhh what does VAG mean .... If I can do what you are talking about ... diable the downshift in tip mode .... I sure as hell want to!!!
Old Aug 8, 2006 | 02:37 AM
  #24
socaljoe's Avatar
SoCal Crew Member
ORIGINAL: shaggys40oz
VAG = Volkswagen Audi Group, Vag-com is a tool used to find out codes and other changes to factory default settings, http://www.ross-tech.com/vag-com/index.html click on link for more info
Old Aug 8, 2006 | 05:29 AM
  #25
ADubyaD's Avatar
SoCal Crew Member
do the b7's still have that extra little click in the gas peddle for downshifting... if they do then give it full gas without clicking the bottom thing, then you wont downshift
Old Aug 8, 2006 | 06:40 AM
  #26
stefanwieckowski's Avatar
hey watsup sorry bout the race, BMW suck ***.
Listen your car shifted down in 3rd gear while driving after you pressed full , becasue you hit the kick down button at the bottom. If you press full without the kick down the car will not shift down.
But still i have the same opinion like you bout the tiptronic transmission.
Old Aug 8, 2006 | 11:31 AM
  #27
TheJazz7's Avatar
Yeah, great suggestion dude. Makes sense, can't believe I didn't think to research it myself. When I'm at the track, it's annoying 'cause I'll want to floor it, but I can't "floor" it without kicking down a gear...so I'll end up being around 90-99% throttle and trying not to trip the switch, when I SHOULD be worrying about that big blue wall 200 feet away. :-)
Any specifics on how to do it, or should I just STFA? Never used a VAGcom before, I'll try looking someone up in my area that has one. Anyone in Rochester NY with a VAGcom want a free case of beer?
Brichards1
Apr 12, 2009 09:06 PM
coldbud3
Mar 13, 2007 01:29 PM
azheman17
Oct 23, 2006 01:23 AM
EvilA4
Oct 19, 2006 12:22 AM
