Front bumper and water pump help
Old Dec 9, 2006 | 05:33 PM
ese_vega's Avatar
Default Front bumper and water pump help
Hi, im new to the audi world ive been reading some basics about audi's, i jt got a 99 a4 T, that need the front bumper and a new water pump.
Ive been looking for the water pump on ebay but its says that theres 3 kinds (3 diferent codes), where can i find my code ??
as for the bront bumper i would like oem but since im here i might put a body kit, but what are the available body kits for this plataform (b5) and where can i get them cheap ??
apreciate any help
thanks
vega
Old Dec 9, 2006 | 09:36 PM
Zrowcool's Avatar
Default RE: Front bumper and water pump help
while your doing water pump. go right ahead and do the timing belt with it. Not much more money on parts and the labor rate shouldnt change at all since you have to take the timing belt off to get to the water pump anyway. To find the engine code, you can look in the trunk, there should be a sticker by the spare tire well that says the code. Probably AEB since your a 99 but check to make sure anyway. Can also take off the plastic engine cover under the hood (3 quarter turn clips hold it in) and it will be stamped towards the back or on the front right side under the cover on a ear that kind of stick out.
As far as bumper. I suggest OEM if not go with a good aftermarket body kit. Try to stay away from fiberglass as they will chip and crack with potholes and stuff then end up costing a lot to repair/replace. Polyurethane kits are the best for durability. And stick with a reputable name brand that will make its quality, durability, and fitment better than most other "cheap" places. lltek has some nice kits but arent cheap by most standards. ebay also but they have mostly fiberglass stuff. so if your budget is rather tight i'd stick with an OEM bumper and save upfor the kit since it will run you a pretty penny.
Good Luck with the a4 and happy modding!
86f250xlt
Apr 9, 2014 11:52 PM
rj.r1005
Jun 28, 2013 09:13 AM
MetalMan
Jul 19, 2012 09:15 PM
hobbes
Feb 17, 2009 12:25 AM
AdilSD
Oct 15, 2008 01:38 PM
