Fuel in Engine Oil
Old Jul 11, 2007 | 05:28 PM
onepoint8tee's Avatar
Default RE: Fuel in Engine Oil
ORIGINAL: aRIf
Oil catch can catch the oil which goes back to the intake.
Fuel in engine should nothing to do with it, I think.
People in AZ say it could be compression rings. Ones I get it that close to the block, it'd be better to rebuild the whole thing.
onepoint8tee; do you have compression test stuff ? I wanna do compression test see what's up.
Nope I dont have tools for that. I know a guy who will do it for cheap or maybe even free at a shop though.
Old Jul 11, 2007 | 08:33 PM
aRIf's Avatar
Do you have time to to take me there on friday? or give me his address or anything.
Old Jul 11, 2007 | 11:52 PM
wood_e's Avatar
try doing a leakdown compression test to check the rings out
Old Jul 12, 2007 | 09:46 PM
aRIf's Avatar
I got bored and I took the valve cover out;
And this is the cylinder head. it's all black there is like carbon on it it gets worst on the other heads step by step.
Old Jul 12, 2007 | 11:30 PM
auditech79's Avatar
ORIGINAL: onepoint8tee
I thought when you run an oil catch can, it eliminates the pcv valve?
You don't have to run a pcv valve with an oil catch can, but i would still use some type of pcv valve on any engine.
As for the compression rings being bad i really doubt it, un-less your getting close to 200k on the clock and im sure you use synthetic so it should be cool.
Old Jul 12, 2007 | 11:34 PM
aRIf's Avatar
I have 155k so far.
onepoint8tee you should help me to do compression test tomorrow. I bought the gauge and stuff.
Old Jul 13, 2007 | 01:05 PM
wood_e's Avatar
do a leakdown test too!
Old Jul 13, 2007 | 02:38 PM
  #18
aRIf's Avatar
I just finished compression test
I did 2 tests. Second test results are in the parantesis.
I think the reason first numbers are lower because I was little nervous to crack it.
Firewall
____
| 0 | -> 175 (180)
| 0 | -> 166 (170)
| 0 | -> 164 (180)
| 0 | -> 159 (186)
Front of the Car
Do they look ok?
Old Jul 13, 2007 | 02:52 PM
  #19
auditech79's Avatar
The front one thats at 159 (i assume psi) is a little low, re-check that one and make sure thats what it is.
Old Jul 13, 2007 | 03:06 PM
  #20
auditech79's Avatar
Ok, i just looked it up for your engine.
New engines 10-13 bar = 147-191psi
Wear limit 7 bar or 102 psi, so your engine is still bordering compression of a new engine, so the rings are out.
