fully depressed pedal?
Old Oct 29, 2006 | 06:31 AM
euphoriA4's Avatar
Default fully depressed pedal?
so, is the fully depressed accelerator pedal of any mechanical significance? it doesn't trigger my turbo, right? does it do anything other than provide some landmark in the flooring of my car? (I'm talking about how when you press the gas pedal down, it goes smoothly until it hits a barrier, which you push through, much like a button, to the final depression of the pedal.) what mechanical ramifications does the pedal serve?
Old Oct 29, 2006 | 06:56 AM
chaos92287's Avatar
Default RE: fully depressed pedal?
wtf? i have no idea wut ur trying to say. there's a barrier for the pedal? i know it wouldn't trigger the turbo tho. the turbo just kicks in at a certain rpm
Old Oct 29, 2006 | 10:58 AM
david9999's Avatar
This is a drive by wire car. There is a transponer that sends a signal to the ECU to control the throttle. The force as I recall is not totaly linear.
Old Oct 29, 2006 | 03:19 PM
dankhound's Avatar
That resistance you feel at the very end is the kickdown switch. It tells the trans to drop a gear for increased acceleration.
Old Oct 29, 2006 | 04:53 PM
euphoriA4's Avatar
so just don't concern it? like, if I'm flooring it, keep it held down, but otherwise don't worry about it?
Old Nov 1, 2006 | 02:19 AM
dankhound's Avatar
Yeah its a normal condition. The ecm should see 100 percent throttle before the kickdown point, but it cant hurt to put it all the way to the floor. Theres actually a basic setting for it in the vag com. The throttle adaptation is basic setting 60. The kickdown adaptation is 63. So if your not getting a trans kickdown when you hit that spot at the end, it may need to be adapted.
PunchyTable
Mar 15, 2009 01:56 AM
lowttfm
Mar 17, 2008 05:13 PM
lorenz
Dec 10, 2006 01:52 PM
