gas problems
im trying to get my 90 audi 80 started and there is gas leaking into the top of the cylinder head under the valve cover.. I know damn well that isnt normal, what can cause that? Could a timing issue be the culpret?
I doubt it's timing related. I'd suspect leaking injectors maybe - have you ever taken them out? If so, the O-rings could be torn and allowing leakage also. If you pull the valve cover you should be able to see some evidence of where it's coming in (like a wet "trail" that shows where the gas is running down). Try that out and put up pics of what you find and maybe we can narrow it down more.
Smokin Tubes
Feb 5, 2012 10:11 AM
commedecargons
Nov 9, 2005 06:43 PM
