GIAC Chip - surging issues
Old Mar 29, 2006 | 02:26 PM
north5995's Avatar
Default GIAC Chip - surging issues
Hey guys,
So I have the GIAC Plus chip on my 2000 A4, probably for about a week now. I have a forge 007 DV and put in a new N75J valve thanks to clconversion. I am having some surging between 5-10/11 PSI. I am wondering if it has to do with my spring - I have the green spring in there right now which is the easiest one to open. Should I put a stronger spring in there? Under WOT 15-18 PSI no surging and between 0-5 PSI no surging so its odd.
Old Mar 29, 2006 | 04:57 PM
BadLuckAudi's Avatar
Default RE: GIAC Chip - surging issues
Mine did that untill I put the N75 H valve in and now its gone..... or it could be the ecu adapting still
Old Mar 29, 2006 | 11:18 PM
north5995's Avatar
I either have an H or a J in there, I don't remember which one, regardless it brought the surging down. How long did it take for your ecu to adapt?
Old Mar 31, 2006 | 12:49 AM
fcanozo's Avatar
It'll does by itself
Old Mar 31, 2006 | 01:47 AM
onepoint8tee's Avatar
adaption takes a few weeks at most... You can assume that after a month it is adapted. Make sure you are using premium gas.
Old Mar 31, 2006 | 01:35 PM
north5995's Avatar
Yeah I did the TB adaptaion, then hooked up a code reader to find I had a TB related code. I cleared that, ran through a tank of 94 and it runs like a freakin race horse now.
Old Mar 31, 2006 | 01:48 PM
ShaodwMav's Avatar
may sound like a dumb question but whats a n75h/j valve????
Old Mar 31, 2006 | 02:16 PM
its the electronic boost regulator, and the h/j is the part number end of two different ones that are higher boost than stock
Old Mar 31, 2006 | 02:37 PM
ShaodwMav's Avatar
should i change mine...or wait till it fails?
Old Mar 31, 2006 | 04:03 PM
north5995's Avatar
I don't think it will fail, it just holds your boost at a higher level.
johnatl_1
Nov 20, 2013 07:45 PM
boostedLTH
Oct 4, 2013 06:55 PM
ware1620
Feb 28, 2008 03:07 PM
Brandon2000s4
Sep 14, 2006 03:08 AM
dfera
Aug 22, 2005 08:43 AM
