guys, I need some knowledge sharing....
Old Jun 18, 2007 | 11:21 AM
madorc's Avatar
Default guys, I need some knowledge sharing....
Hello, its been a while since my last post, and im here again because I need some input on my situation....
Ok... last Friday I stood in line about 2 hours[:@] at the border crossing back to USA, the car did not overheat, at least the gaugue didnt register more than normal temp.
So after finally crossing, I stopped at the gas station, and I noticed a weird oil smell, and after looking under the car, it was leaking redish/kind of yellowoil.... from the drivers front side[:@],so not being able to check the ATF oil level I moved it to the nearest safe place, it stood there for a while.....
After like 30 min, it took it home, no apparent tranny problems.
So the next day I looked at the power steering oil, and it was gone! so i filled it up, and it has not leaked again..! ??[&:]
So my question is, what could have caused this?? car is not overheating, no PS problems, and no tranny problems.... (A/C was on most of the time)
1997 A4 1.8T FWD.....
Any ideas???
Old Jun 18, 2007 | 11:27 AM
onepoint8tee's Avatar
Default RE: guys, I need some knowledge sharing....
Have you gotten underneath the car to look for where the leak may had come from exactly before?
Old Jun 18, 2007 | 11:45 AM
madorc's Avatar
yes, I have looked in detail to where it comes from, it was leaking and still stained from the tie rod at the drivers side, it seemed to be leaking torwards the tire, not inside the engine compartment.....
definitely was not leaking from the PS hoses........
Old Jun 18, 2007 | 11:51 AM
Yeah thats strange cuz tie rods dont leak... Any way you can post a pic?
Old Jun 18, 2007 | 11:54 AM
madorc's Avatar
umm, yeah, I'll go take one, but i doubt we can see anything, cause its not leaking anymore.... and no damage is visible, what exactly do i take the pic of??
Old Jun 18, 2007 | 11:58 AM
I dont know man, dont worry about it.. Just keep an eye on your fluids. I dont know how much help anyone can be if everything is back to normal. Did you look at the inner tie rod that comes out of the steering rack for leakage?
Old Jun 18, 2007 | 12:01 PM
madorc's Avatar
No prob, I appreciate any help or input...
To answer the last question, I cant see that deep in, but I dont see any leak under the car, or any PS fluid shortage... so I think ill just take it to the dealer to further inspect.... im lost here....
Ill come back to post after final veredict...
Thanks!!!
Old Jun 18, 2007 | 12:12 PM
Taking it to the dealer is hardly ever the best solution. With some pics and detailed descriptions from you about whats going on will usually getyou good help from us andend up saving you a ton. If that doesnt work, at least find a trusting independant mechanic. Try this though- With the engine on, turn the steering wheel all the way to the right and hold it there for a minute, and to the same turning it to the left, then check your fluid level and ground for leaks. It might only leak when turned one way or the otherto the extreme.
Old Jun 18, 2007 | 12:44 PM
acetrebo's Avatar
ORIGINAL: madorc
Any ideas???
Well, that seems like the problem. I dont know why it leaked, but if all the fluid was gone, the location of the leak is righht where the PS resevoir is, so, you may want to keep an eye on that, see if any of the hose clamps need tightend or anything.
Kind of strange though.
Old Jun 18, 2007 | 12:49 PM
mark_2328's Avatar
ORIGINAL: acetrebo
Well, that seems like the problem. I dont know why it leaked, but if all the fluid was gone, the location of the leak is right where the PS resevoir is, so, you may want to keep an eye on that, see if any of the hose clamps need tightend or anything.
Took the words right out of my mouth Acetrebo.
