Hard or impossible starting A4 1.8T
Old Jun 9, 2006 | 09:52 PM
Thetuna325's Avatar
Default RE: Hard or impossible starting A4 1.8T
i have had the same problem with my 02, it happens seldom, but every once and a while. does the 02 A4 have any recalls?
Old Jun 9, 2006 | 11:09 PM
Chill72's Avatar
Member
Clean and re-install your throttle body, that will fix it.
Old Jun 9, 2006 | 11:42 PM
CRAZYHAWK's Avatar
Disconnect the battery and reset the throttle body. Make sure you have the radio code.
Old Jun 10, 2006 | 03:05 AM
theguy1084's Avatar
i had the same problem and took it to the dealer under warrenty and the had to relearn the computer. Its called throttle adaptaion. the eccel pedal is drive by wire so sometimes the ecu can get out of sync with the throttle body for odd reasons and when you press on the throttle and tell it one thing and the computer is telling the throttle plate something else something else. this seems to be common with the B6. If its still under warenty i would take it to the dealer
Old Jun 10, 2006 | 03:11 AM
theguy1084's Avatar
BTW no matter what you people say there is no better service tech than the dealer as far as this stuff....talk to independent shops and see what they say about a B6 or B7s or any new model of any brand..............nothing cuz they dont know
Old Jun 14, 2006 | 07:42 PM
krazyvan's Avatar
Just an update....no codes to speak of. Cleaned the TB and reset the computer....all seems to be well so far. BTW the TB was filthy!!! thanks for all the advice.......
Old Aug 6, 2006 | 08:30 PM
MilitantGrunt's Avatar
Any chance that this could happen with a B5? Having a very similar issue here and happens when engine is cool.
gator
Sep 19, 2008 10:50 AM
jhsteel82
Aug 23, 2008 11:59 PM
IDUA ORTTAUQ 6A
Sep 17, 2007 08:08 PM
FOUR Os
Nov 27, 2006 10:59 PM
montic
Sep 22, 2005 10:53 PM
